Device Grouping Association or scripting ?
Guest jfn
Hi all,
First of all I apologize if my question is basic and has already been answered many times.
I am beginning with Fibaro HC2.
On the wall, I have 2 zwave switches with 4 buttons each from MCO home.
and a MCO Dimmer
Basically what I want to achieve on the simplest way as it is possible :) , is to synchronize the behavior of that 2 switches/4buttons that are on 2 opposite sides of the room.
button #1 can switch on/off buttons #2, #3 and #4
button #2 can switch on/off a Qubino dimmer controlling lights circuit A
button #3 can switch on/off a Qubino dimmer controlling lights circuit B
button #4 can switch on/off a Qubino dimmer controlling lights circuit C
-> of course is button #1 changes state to "ON" on the first switch, then the button #1 on the second switch must reflects it too. the same for buttons #2/#3/#4
The dimmer, will be able to dimm + or - all 3 circuits A/B/C
Thanks folks for the help :)
可以参考这个
