Scotsh 0
we have 4 outdoor lamps with integrated motion sensors installed around the house. I want to integrate them into our Fibaro System.
The lamps have a feature to switch to continous lighting if the light switch is set to OFF -> ON -> OFF -> ON. This sequence should happen in less then a second.
I tried it with one of our existing Double Switch 2 and wrote a scene to activate that sequence. It seems that Double Switch 2 is not able to reliably execute this sequence if i choose delays for each switch to match the 1 second threshold
As the Double Switch has an audible "click" when switching i guess this is a technical limitation.
I now have seen that there is a new Double Switch (called Double Smart Module) ->
I tried to find any information in which way the the new switch is superior to the Double Switch 2, but to no avail. I was hoping maybe a faster shifting time.
Does anybody have any suggestion how i could execute the scene with any Fibaro device? Or any other compatible Z-Wave device?
