Scott 1
Hi All,
I've just had added a Double Switch 2 to a light (only using S1) and I've set Param 20 to Momentary and checked all of the Param 28 boxes. So now if I double/triple/hold click I can do different things with CentralSceneEvents via lua and that is working fine
However only when I single click do I want the light to toggle on/off. I don't want this behaviour of the light toggling when I double/triple/hold click. Is there another parameter I should be changing to achieve this?
Thanks,
Scott
Edited by Scott4 answers to this question
