Help translating curl https request to lua
Hi
I'm updating the Daikin air conditioner VD to support thenew model wifi interface (Model BRP072C42), which use https rather than http to connect.  I have found (and greatly cleaned up) the existing Daikin VD on this forum.  Now i am trying to add support for the https interface.
I understand this will need the https request to be handled by a scene.  The VD will submit the request via a global variable and receive the results similarly.
A sample request, which works using curl is as follows:
This doesn't appear to use any security (user, password) so will the following code work:
Sadly this code works but produces no output from the HTTPS request call, and even if I overwrite the url to the HTTP request shown (commented out)  in the code, which produces a valid response in my web browser.
Obviously I will upload the finished VD and scene when done.
Edited by codowd
corrected code
4 answers to this question
JFYI: XML responses doesn't showing in HC2 debug windows.
    Indeed, thank you.  The global variable is being set to "ERROR: Operation canceled".
    Trying to get the simpler HTTP call working, I do (rarely) see the red error message in the debug window.  if I change "POST" to "PUT" I get a different error "End of file". and it always shows.
    I never see the debug message with the HTTPS call.
    Edited by codowd
    more information
    @codowd Digging up an old thread, did you ever get this working?
    success debug is never shown because the called function is different to the one declared.
    Change "success = httpResponse" and the debug message will show.
    I've tried this (on a HC2) but getting stuck with a 403 error.
    I can get the Daikin BRP072C42 cURL commands to work fine on my PC but sadly not able to figure out how to translate this across to a HTTPS request in a LUA scene from the HC2...
    Edited by mmmhosk
    Guest Theo
    This function sends a https request to a Homewizzard PiB. When executed with 'curl --insecure' it works just fine. The Fibaro alternative checkCertificate does probably not work. It gives as "success" output the text "user:unauthorized".
    The alternative is to send the certificate. Does someone know how to do that? Should it be sent as an option?
