Update 1.8.0 is live and the app still crashes on VDs. Well done, Fibaro? At least you are consistent :)
Edited by baskalex
" to "
Temat został przeniesiony z "
" do "
I have the same. It’s still not solved since the first release?
I want to switch to the new app, but when all of VD’s can’t be used it is useless.
It is highly possible that the problem is related to a specific VD. In order to determine which one it is, one would need to create/use a user who does not have access to all VD and start adding access to them one by one.
The moment the app crashes it should be that very device that is causing the problem. Would it be possible to perform such a test?
Hi @K.Drozynsky
Thank you for your response and advise. It occurs with all my VD's, even the ones that only haves simply thing turn on light x. But the issues also occurs when I open the VD without pressing a button, so read only. The app keeps crashing sadly?.
Kevin
    Hello and thank you for some feedback. The problem is not related to any concrete VD. I’ve tested it on empty VD with just 2 buttons and no code. However it is somehow related to VD icons. If VD has no icons (blue box) everything is fine. If VD buttons have icons assigned (even if the icons are the same) it will crash. I can make a video if this helps. This has actually already been discussed on the forum and reported. The bug however is still there and has been there since the first version. I actually prefer the new app to the old one, but can’t use it because I rely heavily on VDs.
    @baskalex a video would be much appreciated. I will forward it to the appropriate engineer immediately.
    @K.Drozynski Here you go. Screen capture from my phone (iPhone 11 pro max) and a screenshot of VD from my HC2 web UI.
