Hi guys!
Is it possible for me to controll scenes with my watch? (Fenix 6 by Garmin)
I just have HC2.
Thansk for replies.
Apparently this is possible. Have you tried the Garmin app MyHomeControl by Redneck?
  • 3 years later...
Hi all,
Is someone using this app on garmin watch?
I can't find out how to get an url of the Fibaro HC3 scene to run it from watch/browser.
I found this "http://LOGIN:PASS@IP/api/sceneControl?id=SCENE ID&action=start" but it doesn't work for me.
I'm trying to run: http://user:[email protected]/api/sceneControl?id=15&action=start
What is the correct syntax pls? Or is there some other problem?
On 7/3/2020 at 7:49 AM, LeRooy said:
Hi guys!
I just have HC2.
Thansk for replies.
Did you try in Yubii application (runs on mobile phone) to activate watch option? It should run a scene or widget from your watch
Edited by cag014
8 hours ago, PeterHorsky said:
Hi all,
try that
for HC2
http://user:[email protected]/api/scenes/15/action/start
for HC3 paltform
http://user:[email protected]/api/scenes/15/execute
But this is a POST method, not a GET, so it won't work on browser.
Edited by cag014
Perfect, I can successfully run this command from mobile web browser, but it doesn't work from myHomeControll garmin application.
I get "Request timed out Try again!". I wrote to the developer of that app to provide correct setting ;).
I'll update here if I receive something useful.
PS: the instruction of the developer on the official garmin page:
Type/copy/paste the URL to trigger a device action (without http:// or https://, don't use them because you'll get an error :-) ) (e.g. 192.168.2.1/sw/23_and_command=on). You can add (optional) a json body as parameter of the url as well. (e.g. 192.168.2.1/sw/23_and_command=on?jspost={value1:morning,value2:11.00}). You can use jspost, jsget, jsdel and jsput as methods. Type "_and_" or "_perc_" or "_space_" or "_po_" or "_pc_" instead or "&" or "%" or " " or "{" or "}" in the url to prevent saving problems in Garmin Connect. The "_xxx_" symbols will be translated before executing the command.
Peter
Edited by PeterHorsky
And? Any feedback.
No. The developer didn't answer my questions. No support from his side at all.
