In 1.7.0 and earlier releases: Blinds showed icon open when closed and closed when open.
  • 4 weeks later...
When I changed to custom icons - like half open blinds at 50% etc - this does not show up in the iOS app - it either has the 0% or 100% icon only even if at 30% or 75% etc?
  • 1 month later...
    Same for me icons show 0 or 100 no other value.
    Biggest problem is dashboard in app where it’s easy to think its 0 or 100% instead its value 10-90, in my case a fan in bathroom.
    • 3 weeks later...
    Same problem with my HC3 and all my 3 Roller Shutter 2 : when the blind is open, the icon show a closed window.
    Is there an issue for that strange behaviour ?
    • 1 month later...
    Same here with HC2 and a double momentary switch. If I control it from the dashboard or app, the status-icon changes. However, when I use the momentary switch, it shows the 'closed' icon only. When I try to change the icons, the field shows as empty and when uploading new icons, it never succeeds. Any ideas??
