Good morning
i have a HC2 ver.4590 with a little problem:
every time he removes the voltage at home he doesn't restart, is that normal?
the HC2 is positioned in the center of the house in a slightly uncomfortable attic for manual ignition, how can I solve it?
8 answers to this question
3 hours ago, Fabrizio1969 said:
Good morning
My HC2 periodically doesn’t restarted after power outages. It annoyed me. So I have powered my HC2 via UPS.
another watchdog was via raspberry pi
if rPI was succ booted but ping to HC2 doesn’t work rPI send to WiFi plug SonOff command to power off and after 1 min power on
than script trying to check ping HC2 again and looping if not
yes, maybe easy way here is RMA, may you have a some hardware failure here, but idk what is right ;)
change the internal battery and it will restart :)
Clock batt? Wow, I forgot about it! Yes!
Guest cuprum
On 7/6/2020 at 6:56 PM, Fabrizio1969 said:
he doesn't restart,
Little bit more specific? ;)
What the "restart" means - the power up or system ready - here.
Does the front LED's lit up aft power outage or the system stays just dark?
Actually, as there is a "ordinary PC" inside the HC2, then there may be several reasons to "stay dark":
a. The BIOS is set to stay of after power failure (aft. power restore the system stays dark till power button pressed).
b. There is something wrong with BIOS/hardware config (for example the RTC batt)
May-be the best way to solve the problem is to connect a monitor and keyboard, and look, what's happening, if the power restores.
    ok I look for the battery and replace it, a question but if I replace the battery what am I going to meet?
    loss of some data?
    Buongiorno
    finalmente ho un momento per aprire il mio HC2, l'HC2 è usato e il vecchio proprietario ha già cambiato la batteria (foto1 e foto2, non ha fatto un buon lavoro stabile).
    Volevo chiedere se il cr2032 è adatto come batteria.
    hey, in the picture you can see what and how.
    Thanks you were very useful?
