Upgrade went smoothly ...  Software Version:4.600
    " to "
    Temat został przeniesiony z "
    " do "
    Upgrade went smoothly yesterday ... no issues till now.
    As always, no problems with update. It remembers setting for front panel LED intensity now ;)
    Edited by jwq
    Update went smoothly but let's see the coming days how the HC2 keep performing:-)
    Hi, i updated HC2 to 4.600.
     It hasn't been accessed remotely since I updated it, and the finder can't find it either.
    I  can't restore to previous version because i can't download the installation file  :(
    the third led does not light either
    I can access it from the local network with the ip address
    Edited by Bari Zoltán
    Upgrade wrecked havoc with my Amazon Alexa setup. All Fibaro devices were unresponsive. Had to roll back to 4.590.
    Hello @Bari Zoltán . Did you write to Fibaro Support about this issue? I had the same problem, they performed a remote conecction through Open port of my router and fix this issue.
    Hi Andrés, Thank You, i write them now. They did the restore to 4.590  from 4.600  ?
    Started my upgrade an hour ago.  The HC2 just says "Updating" with the spinning circle.. After refreshing the browser it seems to have hung on "Please Wait Creating backup. Uploading backup to server".  Thoughts anyone?
    UPDATE: A waited a while longer and had to push the power button. It restarted okay and and I could try again (after a clean reboot).  Took a while but came back to life.
    Software Version: 4.600.
    I'll do some testing and update this thread if I find anything.
    Edited by Hankster
    Update.
    This is how I do my upgrades and it never caused any problems.
    Reboot HC
    Make a back-up
    Reboot system
    Upgrade without back-up option
    Automatic reboot
    Make a back-up with the new firmware
    Reboot system
    Done
    Time-consuming but effective.
    Cheers
    Sjekke
    All is fine. Everything appears to be working. Agree with Sjekke on the upgrade approach below.
    • 2 months later...
    Update wrecked my HC2
    The software does not load entirely anymore with no means of rolling back because the backup option is no longer working. The Interface I get after the Recovery option is not working.
    Is there a way to recover to 4.590?
    • 4 weeks later...
    Update went smooth on all my 3 HC2. Did update a week ago and till now didn't notice any problems. Also adding z-wave devices works OK.
