I have POPP Z Weather station.
When I install it on Fibaro HCL controller it says that device has no template to be configured.
Is this device supported by Fibaro?
5 answers to this question
1) most non Fibaro devices without tempales and this is ok behavior.
2) commiserate. this meteo station was sold after 1 week. ugly implementation as for me. this meteo station a most time sleeping, you will have some more issue, it just for you info. not more than.
Edited by 10der
    now when I have it, I would like to do what ever is possible. I simply have "not configured" on all 8 items produced by this weather station in Fibaro. And there is no wind speed at all which was the only reason why I got this.
    @Damir Popovic reconfigure again
    as far as I know when I bought this device (was 2 y ago) I was have the similar issue with HC2
    but after 3 or 5 trying I can connect POPP metro to HC2
    one of issues was : as far as I remember POPP meteo doesn’t have own batteries if powered only via sun and when you bought this meteo and trying to pair... the power what you have not enough for ending interviewing... and HC2 do not getting full information about your device
    1) try to charge station
    2) key pair button more time after start pairing
    3) do soft reconfiguration for trying to start / continue pairing
    as fact unconfigured devices its not what you do not have templates for this device and cuz not ended interview
    alas
    please keep me in loop here.
    after I exchanged few e-mails with their support we found out that device is broken and we agreed that they will replace it
    Perhaps this helps:
    A. The "Storm Wake-up" (Device 212 → Parameters)Parameter 1 (1 byte): Value 6Effect: As soon as the wind speed exceeds 6 m/s (≈ 22 km/h), the sensor wakes up immediately and transmits — without waiting for its normal reporting interval.
    B. The "Automatic Clear/Reset" (Device 212 → Advanced)Wake-up interval: 900 seconds • Effect: The sensor reports every 15 minutes, even when there is no wind. This ensures that the alarmStatus automatically returns to false once the storm has passed.
    This combination makes the device react very quickly to rising wind speeds while still reliably resetting the alarm status after the wind dies down.
