homebridge-openzwave compatability
Hi
I am trying to get a Roller Shutter 3 to work with homebridge, and in particular homebridge-openzwave, running on a Raspberry Pi and communicating using an Aeotec Gen 5 USB stick.
I am close, but not there yet.
If I send commands to the RS3 by calling openzwave directly from Node, it appears to work.
When I 'deploy' the blind, the openzwave log file records the command :
2020-07-04 19:04:55.213 Info, Node004, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Level - 0 - 1 - 99
and the RS2 closes the first relay and opens it again a second or so later.
When I 'retract' the blind, the openzwave log file records the command :
2020-07-04 19:04:55.213 Info, Node004, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Level - 0 - 1 - 0
and the RS2 closes the second relay and opens it again a second or so later.
That all seems good and has inspired me to continue banging my head against this brick wall!
But when I try to deploy the blind using the homebridge UI, the homebridge-openzwave plug-in sends a different command:
2020-07-07 12:33:49.190 Info, Node004, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Level - 0 - 3 - 255
and the roller shutter appears to ignore it.
And then homebridge-openzwave sends another command shortly afterwards:
2020-07-07 12:33:49.511 Info, Node004, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Level - 0 - 3 - 99
That looks like the correct value, but still the roller shutter ignores it (3 versus 1?).
I am hoping that someone who understands more can tell me if, as I suspect, homebridge-openzwave is sending the wrong commands.
Or should the commands work and there is a different issue?
I am not sure if it is relevant, but the RS3 is straight out of the box. It has not, for example, been calibrated.
All help gratefully received.
Mike
can you write more what you sending?
99 look like value (RS support from 0-99)
but what mean 0 and 1 in your log? which version command class you use?
    Hi
    Thanks for responding.
    Are you familiar with the openzwave software? I am learning as I go. The lines are from the two openzwave log files:
       working (Node javascript code calling the openzwave library)
    and
       not_working (the homebridge-openzwave homebridge plug-in calling the openzwave library).
    I have found the line in the openzwave source code that prints this entry out:
       Log::Write(LogLevel_Info, m_id.GetNodeId(), "Value::Set - %s - %s - %d - %d - %s", cc->GetCommandClassName().c_str(), this->GetLabel().c_str(), m_id.GetIn\
    dex(), m_id.GetInstance(), this->GetAsString().c_str());
    So it appears to be:
       Node id: Node004 = wave node 4
       CommandClass:  COMMAND_CLASS_SWITCH_MULTILEVEL
       Label: Level
       Node index: 0
       Node instance: 1
       New value: 99
    Does that make sense to you?
    The log files include the line:
       CCVersion: 1
    so I presume they are command class version 1.
    I will continue to dig deeper...
    Mike
