Jeroen_ 20
2 days ago, I updated my HC2 to 4.600 and now I can't control the dim level on all of my lights through google assistant (all fibaro modules). Before this worked flawless. After the update I can only turn the lights on and off. Does anyone know a solution to fix this?
I installed 7 roller shutter 3 modules this week. They work through google assistant, but it works on incremental basis and not absolute. For example, if the shutters are open and I say "set shutters to 15%"it closes to 15 %, if I then say "set shutters to 50%" it closes to 65% (15+50). To open them I have to say, "open shutters 15%". I would like to use absolute values for this. Example: command "set shutters to 50%" it should open to 50%, followed by "set shutters to 15%" it should close to the 15% position. Is this possible? With absolute values it is easier to control them all in one command.
Thanks in advanced!
Edited by Jeroen_13 answers to this question
