Szakos 0
I want to write presence simulation if nobody are in home with random light on.
For the Dimmer and RGBW controller I don't want to lost the adjusted data, but in the simulation I want to use maximum light power ( value 99 ).
My idea is in the scene before start the simulation cycle I want to read out the adjusted data without turn on the lamps and this data is put in temporary variable.
Run the presence simulation.
After presence simulation all lights turn off and put back from the temporary variable the original adjusted data to the dimmer and rgbw controller. If I will come back to home and turn on some lamp it must be lighting with the originaly adjusted data instead of the maximum light power what I use for the simulation.
Can somebody hel me how to do it ?
Best Regards
Akos
