Hello everyone
I am somewhat new to the world of Fibaro systems.
Having a look around through the forums I have noticed there are a few people trying to import their solar smart meters into Fibaro through VD.
Whilst trying to learn Fibaro I am currently an Australian solar installer and wondering if anyone on here has coded the following inverters or could point me in the right direction.
SMA
Fronius
Sungrow
Solax
Thanks in advanced
22 hours ago, PSi said:
Dodajesz Quickapp do HC3 i dodajesz parametry połączenia API Solarman jako zmienne.
Dostęp odbywa się za pośrednictwem interfejsu API Solarman w chmurze
Or I'm blind, maybe I can't read :)
But I see only interactions with specific inverters and not with the Solarman Application?
On 4/8/2023 at 9:22, iwo said:
Hola, ¿alguien tiene inversores solares Victron integrados?
Encontré algo para HC2 pero necesito para HC3.
Tengo
3x Multiplus II
2x MPPT 250/100
Cerbo GX
4x batería Pylontech US3000C
tengo hecha un aplicacion si te interesa escribeme
On 19.9.2023 at 11:48, wojtas810 said:
Oder ich bin blind, vielleicht kann ich nicht lesen. :) :)
Aber ich sehe nur Interaktionen mit bestimmten Wechselrichtern und nicht mit der Solarman-Anwendung?
Hi, I integrated the Solarman API, this supports multiple Inverters (Solarman, Azzurro, ..)
3 hours ago, PSi said:
Cześć, zintegrowałem interfejs API Solarman, który obsługuje wiele falowników (Solarman, Azzurro, ..)
and where can you find it?
I can send you the files, for now it is only my private project
17 hours ago, PSi said:
Pliki mogę przesłać, na razie jest to tylko mój projekt prywatny
Nice seand you priv my e-mail
On 8/18/2023 at 11:53 AM, HomeSystem-Slovensko said:
We developed Growatt invertor QA to integrate to HC3. It is available here:
@HomeSystem-Slovensko
I am very interested in your product. Do you have any more screen shots other than the one of the devices created shown on your website? I’d like to see some images of it integrated into the energy panel on the Home Center. Also does it show battery information: SOC, storage production etc.
Is your website available in English?
Edited by Merlin
On 8/8/2023 at 13:10, PSi said:
He desarrollado una integración básica para el inversor SolarMan / Azzurro, contácteme si está interesado
Hello, I have a solar deye inverse that uses the same solarman wifi usb and the same application, could you help me with the quick application, thank you
Cześć,
Jestem bardzo zainteresowany Twoim produktem. Czy masz więcej zrzutów ekranu innych niż te, które zostały utworzone na Twojej stronie internetowej? Chciałbym zobaczyć kilka jego zdjęć zintegrowanych z panelem energetycznym Home Center. Czy pokazuje również informacje o baterii: SOC, produkcja pamięci itp.
Czy Twoja strona internetowa jest dostępna w języku angielskim?
Pozdrowienia,
describe a little more how it works because the website also contains laconic content
I purchased the QA from @HomeSystem-Slovensko and finally have my Growatt inverter data in HC3. 😀 What I can not do is select any of the ‘Energy / Power’ meters as ‘Production’ meters within the Energy Panel the Production Meter fields remain grayed out. Is there something I have to do, to allow enabling of these fields? It’s frustrating that I now have the data in HC3 but not yet into the Energy Panel.
TIA
TIA
did you manage to solve it?
Alas no!
I found a ready-made quick - I recommend it
Hi All
any ideas how to deal with GoodWe inverters API? I'm trying to integrate with SEMS portal, but without luck. There is nothing in marketplace for GoodWe.
Im trying to write my own scene based on
 but my coding skills are not enougt.
On 19.07.2024 at 14:04, Martinnnnn said:
Cześć wszystkim
jakieś pomysły jak sobie poradzić z API falowników GoodWe? Próbuję zintegrować się z portalem SEMS, ale bez powodzenia. Nie ma nic na rynku dla GoodWe.
Próbuję napisać własną scenę w oparciu o
 , ale moje umiejętności kodowania są niewystarczające.
Sprawdz, czy możesz wykorzystać Aplikację SolarMan - jeśli tak masz gotowy Quick wyżej i działaj :)
Używam HC2, wiec Quick App odpada. znalazlem na forum QA ktora uzywa udp po sieci lokalnej i pzrepisalem na urzadzenie wirtualne ale utknalem na jakims problemie z otwarciem socketu udp.
Integracja przez SEMS API połowicznie udana, łącze sie do uslugi CrossLogin, ale odpytanie o dane falownika konczy sie statusem 403..
(This is the English section)
On 9/18/2023 at 1:46 PM, PSi said:
You add the Quickapp to HC3 and add your connection parameters of the Solarman API as variables.
The access is via the Solarman API over Cloud
Hi
I'm interested in integration between hc3 and SOLARMAN.. can you give me info about it?
Clink this link, and look
@ZFIBAROzaPanBrat
Edited by wojtas810
Hi
The latest integration for hybrid inverters with option to set energy flow priority - allows you to set the inverter mode, e.g. according to dynamic energy tariffs
Growatt:
Deye (and SunSynk):
and more similar (Huawei, GoodWe, SMA, Tommatech, Solax, QCells). All using Modbus, so works localy (not via cloud) and immediatelly. And what is more, they allow to change charging/discharging options for battery, so you can control battery storage based on dynamic energy costs.
Edited by Albert
