Driving me crazy with 2way installation
Hi guys
I need some help with a 3-way instalation. I saw hundreds of diagrams, reading thousand of forums, but I can't make go a Dimmer 2 into a 3-way installation.
First of all I'm newby and my electrician knowledge are very small.
I have two Bticino toggle on/off switch, with 3 cables each (1-2-L). The switches work perfect, but not with my dimmer 2. I can't identify the live and neutral, and the colors change in some point between the switches and the bulb. I have and electrical box with all the conexions and cables and think is here the best place to find all the cables that I need.
Please can someone tell me which cables and where do I have to put them in dimmer 2? but an explanation for a dummies :-)
Thank you so so much
Edited by Decorpc
Change 3way for 2way
7 answers to this question
Can you switch the light with one of the switches, ON and with the other switch OFF??
    Yes, no problem with that
    Hi @Decorpc,
    You could connect like this.
    But I would buy a voltage tester, and if you're not really sure about things ask a trained electrician.
    No warranty given.
    Tank you Flash for your diagram. Tomorrow I'll try it and ask a friend who is electrician, but we don't know what and where have to connect the cables.
    Again, Thank you very much
    28 minutes ago, Decorpc said:
    Thank you very much
    Good luck tomorrow, keep me posted.
    Edited by Flash
    just connect 2 (two)
    downstairs
    upstairs
    and connect one of to lighting :)
    scene (HC3)
    PS: I am use Z-Wave NEO Coolcam Light Switch — NAS-SC01ZE
     Hi Flash, your desing works PERFECT ??
    I used a conection box to find all the cables (also I had to add new one from one L to dimmer)
    Thank you very very much
    downstairs
    upstairs
    scene (HC3)
    Thank you for this option.
    I'll save it just in case i'll change que inerruptors.
