Rds 0
I installed the dimmer 2 with a bypass to dim a rail with sqube spots from Wever & Ducré. I can switch the spots on and off, but I cannot dim them. I have already adjusted parameters 13 and 30 (and also 1 and 2) but that does not work. When I remove the bypass, the first 2 spots (of the 6) flash when the dimmer is off. The dimmer is connected with 3 cables.
Does anyone have a solution?
