Installation best practice for Smart Implant
Hi Guys!
I'd like to ask your experiences with building the smart implant modul into some case or housing. Formerly the universal binary sensor had a good form factor and design. It could be screwed into a plastic box or house, with the screwing terminals let the wiring made easy and pretty between devices. The implant wire harness seems a little bit complicated, only the outputs have terminals for the inputs you have to make the connections somehow and mounting the the implant's body is also seems tricky.
How do you built this device in your works? Could you give me some ideas (photos?)
Thank you so much!
@GTakacs
Did you mean something like that? :O)
Edited by Martin_N
    @Martin_N
    Yes, I mean exactly like that :) Thank you!
    This DIN rail kind house is a very good idea! :)
