Sorry for my (maybe stupid) question but what is the difference between FGS-222 vs FGS-223 vs. FGS-224 smart double switches? I started to buy smart tools for my new house and I don’t want to make a misstake.
Thank you!
Hi @nadtom
If you look here.
There are some differences between max load. and other minor things.
The biggest difference is that the FGS-224 has ZW500 chip.
    1 hour ago, Flash said:
    Hi @nadtom
    If you look here.
    I have checked the manuals but didn’t find any differences, the max. load is almost same. So the ZW500 chip can be a difference but it is important? I mean is any advatage compare to older chip?
    The HC2 can use the advantage of ZW500 chip?
    Edited by nadtom
    @nadtom
    main difference:
    The device is a Security Enabled Z-Wave Plus product and a Security Enabled Z-Wave Controller must be used in order to fully utilize the product
    Hi @nadtom.
     I don't know for sure.
    I think @akatar , can answer this question for you.
    The only thing I know is that, only a ZW500 main powered device can act as a ZW500 router, in you're mesh network. Otherwise it will fall back to ZW300
    Edited by Flash
    That with the ZW500 chip etc. is a difference.
    But there are even more serious differences regarding the electrical connection and the function of the device.
    The FGS-223 as well as the FGS-224 have 2 channels.
    With FGS-223 we have a potential coupling with the supply voltage and a current and power measurement.
    With the FGS-224 we have 2 potential-free channels and it can also be operated with 24VDC. Then with the FGS-224, the inputs can also be end-coupled from the outputs.
    So in my opinion big differences.
    The FGS-224 is therefore in direct competition with the Qubino.
    Take a closer look at the data, not everything can be seen at first glance. Fibaro should add a little more to the advertising.
    Greetings Frank
    Dear All,
    Thank you, now it’s clear.
    You're correct.
    I find the device naming between the switch without and the switch with the relais very similar.
    Would prefer a better naming FGS-XXXR or something. But that's personal.
    couldn't agree more
    couldn't agree more
    Yes, many shops write only that Fibaro double switch...and no any identification number. I didn’t know at the beginning that you can buy different double switch types.
    I have ordered 10pcs FGS-224 today. Thank you guys! Danke schön!
    Edited by nadtom
    Also to add a penny from my side - 222 does not have scene activation functionality (double, triple press etc.). But at the same time it has better activation time and doesn’t have problem with “missed” presses.
    Edited by baskalex
    • 3 months later...
    • 10 months later...
    On 11/14/2020 at 9:19 AM, Johan Falkenberg said:
    Here´s a pdf that explains pretty well the differences.
    That PDF is a joke regarding clarification of TOs question.
    • 1 month later...
    hi
    I have a question please
    the FGS224 does not give the energy consumption ?
    On 11/14/2021 at 12:58 PM, CharlesO said:
    hi
    Hi @CharlesO ,
    According to the manuals
    FGS224 does not have energy consumption, but FGS223 does have such feature.
