Led calibration turns green then red
Hi!!
When connection dimmable led lights the walli calibration process looks ok. First the light is finding it's dimming range (all works) then the walli turns green, next the ring turns white and the light turns on, all working perfect. BUT after a couple of seconds the walli led ring turns red and the light goes off..
What does this mean?
I tried the bypass, but still same result..
Hi talkatoo,
I have same problem, which I coud not solve with bypass. Did you trief auto-calibration with bypass-mode? I think even with bypass, Walli Dimmer needs a minimum power consumption... When my LED-lights are above ~30%, everything works fine.
Did you find solution?
Best regards
Patrik
