Anyone know how to get geolocation working or when an update will be available? Not having this feature after moving from a mature system is a major limitation of owning a HC4
HC3
Just use IFTTT if you don’t get it working on the HC3 itself. You can make two triggers on IFTTT, for leaving or for entering a geo location.
  • 4 weeks later...
I tried to use Block Programming in HC3 and still the same problem, no notification. I also allowed Home Center app for location access but it does not work.
I didn’t even tried it with the HC3 itself. I use IFTTT (although other also have issues with IFTTT) and it works fine.
Here is a link to an earlier post about IFTTT:
Edited by SmartHomeEddy
  • 3 weeks later...
    Now that geolocation is added to home centre 1.9.0, anyone had success with it and the HC3. Not working for me even though iPhone set to allow location access to “always”
    Guest kallecux
    It works with two different user - you have to enable it in the app!
    Greetings!
    Karl Heinz
    Greetings!
    Karl Heinz
    Hi @kallecux , can you tell me some more on how you did this? I enabled it in the app and i made a simple block scene that should give me a push mail if i leave or enter the house. But it doesn't work. The scene does work if i run it by hand, but the geolocatin doesn't trigger....
    any hint is graely appreciated
    Guest kallecux
    Hi @okidoki i did it in the same way and use this simple LUA-Script converted from a block scene:
    Trigger:
    Check the ID - its your user-id!
    Check the property - its the location!
    Action:
    Have you checked the ios-settings to allow the fibaro-app to use your geodata always?
    Greetings
    Karl Heinz
    Thank you, converting to LUA worked for leaving location. Now need to get it to work for returning - working on that
    Guest kallecux
    Try  value=„enter“
    Trigger:
    Action:
    Greetings
    Karl Heinz
    Thks @kallecux , it looks like it works. But very strange for me is why the block diagram doesn't work.  I;ve seen it before, lua works and the block doesn't
    Thks for the example.!!
    one question though, what means the |1| in the push statement?
    best regards
    jacco
    Guest kallecux
    I dont know - ist came from the blockscene. :-)
    haha, thats great!
    never change a winning team.
    • 4 weeks later...
    Just some additional tips: @Nevlev
    - you have to create a fibaro account on fibaro site for every user
    - create the user on the HC3 user tab
    - you have to install the app on the phone
    - login in on the app and enable geofencing there
    - and then: important: go to the installations on your phone, to the app and enable location sharing set to always! (and not just only when app is used!!) (took a while to figure this one out!!)
    - then try the script above and it will work, if you fill in the right id's for the user
    Edited by okidoki
    • 1 year later...
    Has anyone else had issues with the radius around the location when setting geofencing up in the HC3? The minimum I can enter is 150m. This is a huge area around the house.
    • 3 months later...
    Geofencing in hc3.. has anyone had any use for geofencing in hc3 when the radius minimum is 150m?
    Its still give data away or home.
    For me its functioning verry well if I am in the range of 150 m it will start to home/away cycle.
    Its working excellent!
    Remark: If I am working in the garden I dont need my location will be changed in away of garden :)
    //Sjakie
    • 7 months later...
    I read with immense interest your post on geofencing.
    I'm ready for the tests.
    However, I don't know what exactly the value of the expression "property = 219" refers to?
    You specify that it is about renting.
    But expressed in what form? Meters (circumference), degrees, location ID in HC3?
    I can't find any correlation.
    Thanks in advance.
    "property = 219" is your HC3
    If you create a block scene and change if finished in LUA you will see it
    In General>>Location you can set the distance in m
