Z-Uno not all devices appear in HC3
I use Home Center 3 and z-uno. I add 1 general purpose sensor, 1motion sensor 2 door-window sensors and 1 dht11 sensor. The device added to my z-wave network - home center 3 controller but only the general purpose sensor of binary sensors appear and the dht11.
This happens with every binary sensors I add. The home center 3 show only the first binary sensor. Could you please help me to resolve this issue?
Attached: Z-uno code and HC3 screenshot
9 answers to this question
ZUNO
motion
light
temperature
humidity
pressure
relay1
telay2
    I'm sorry, I didn't understand your answer.
    Edited by prokopis
    type error
    @prokopis ok.
    no issues
    Thank you very much for your answer and for your code.
    Unfortunally, if I add one more motion sensor to your code in a different channel (Reserved Channel) and upload the code to Z-Uno and then add the Z-uno to HC3 , the second motion sensor is missing!! That is happening every time I use more than one binary sensor on all my projects! Only the first sensor is appearing on HC3.
    Is it a compability issue or is my fault..?
    Another issue I have (if that helps) is that if I burn Z-uno bootloader with S2 security and add device in HC3 in security mode only package is appearing and all other devices are missing!!
    So for now i use no security mode on Z-uno.
    Edited by prokopis
    Oh... security mode it’s pain for HC2 and HC3
    do not try it. And ZUNO here is not root cause issue
    about multi binary sensors TBH I do not know what happened.
    ok will try on weekend playing
    Thank you very much!
    I had a similar issue - not all my sensor showing up. I then added a ZUNO_SETUP_ASSOCIATIONS line to my sketch which made it work. My channel setup looks like this:
    ZUNO_SETUP_SLEEPING_MODE(ZUNO_SLEEPING_MODE_ALWAYS_AWAKE);
    ZUNO_SETUP_ASSOCIATIONS(ZUNO_ASSOCIATION_GROUP_SET_VALUE); // Send Basic Set to association group
    ZUNO_SETUP_CHANNELS(
      ZUNO_SWITCH_BINARY(getDump, setDump),
      ZUNO_SWITCH_BINARY(getPump, setPump),
      ZUNO_SENSOR_BINARY(ZUNO_SENSOR_BINARY_TYPE_TILT, getFloatSwitch),
      ZUNO_SENSOR_MULTILEVEL(ZUNO_SENSOR_MULTILEVEL_TYPE_TANK_CAPACITY, SENSOR_MULTILEVEL_SCALE_LITER, SENSOR_MULTILEVEL_SIZE_TWO_BYTES, SENSOR_MULTILEVEL_PRECISION_ONE_DECIMAL, getTank1Level),
      ZUNO_SENSOR_MULTILEVEL(ZUNO_SENSOR_MULTILEVEL_TYPE_TANK_CAPACITY, SENSOR_MULTILEVEL_SCALE_LITER, SENSOR_MULTILEVEL_SIZE_TWO_BYTES, SENSOR_MULTILEVEL_PRECISION_ONE_DECIMAL, getTank2Level)
    @JonesDownUnder  Unfortunatelly that didn't work for me. My issue is not solved!
    What Home Center are you using ? Is it HC3?
