Can a standard switch be a trigger?
Hi all,
I'm looking for a solution for the following setup:
I have a qubino flush dimmer connected to a standard switch controlling a lamp. What I would like to do, is that when the motion sensor is triggered, the dimmer sets the lamp to 15%, and when I use the switch itself, the dimmer goes to 100%.
Currently, if the dimmer is set to 15% by the motion sensor, the switch will also only turn the lights on to 15%.
Thanks in advance!
TL;DR;
your script should handle BOTH cases - motion and manual switch.
so
if dimmer was activated by your script (AKA motion) yousetup lighting 15%
if you manually turning ON the light your script should "is motion here" oh no! no motion but somebody turnred ON me. OK let patch dimmin to 100%
if motion detected and lighting is 100% just exit.
    1 minute ago, 10der said:
    TL;DR;
    so
    I have no problem with switching on by motion, but how can I detect that it's switched on manually?
    variable, Carl! :)
    if you turing ON light via script set variable = SelfAction = true.
    if lighting was ON not by script )AKA manual) this variable not be settted as SelfAction = true
    Edited by 10der
