Hi there. I can’t find how to change the setting so that I can use the HomeKit switch from toggle to press. Can anyone help please?
I don't use the Homekit version of Fibaro products, but hopefully this helps. I find this in the manual.
Can you change the parameter as mentioned in the screenshot by using the Fibaro Homekit app?
Edited by kevin
    Thanks Kevin.  Yep. I found it. Works great! Appreciate your help.
    Great!! No problem, the forum is there to help others ?
    Kevin do you know what “bi stable control of the slope” means?
    • 3 months later...
    @kevin @nzdrew - Let me jump in here, too.
    I installed a Single Switch - it works fine, but people need to switch the "physical switch" twice, after some one use the "digital switch".
    Is this setting that you linked above to solve this problem?
    Sorry - not sure if I described it correctly but I'm not an english native speaker :)
    Edited by Maddeen
    • 2 months later...
    I have the same problem of MADDEEN but I didn't solve it.
    Plus, I connected the FIBARO (single switch homekit) connected relais putting in instead of the previous relais but when I press the button it behaves in some kind of TOGGLE MODE. Basically when the relais is working, and when I press the wall button the light goes ON, but as I release the wall button the lamp goes OFF. And after pressing the wall button I’d light the light to stay ON (obviously). To make it temporary work I had to put both the old relais and the FIBARO relais but I don’t think this is right. How should I do to make it work just using the FIBARO relais?
    Edited by lsegalla
