I have an HC2 (for some time now), and I just bought an HC3 ?.
Because it's going to take a little longer to transfer the scenes (I wanted freshen up the scene anyway) I want the HC2 and HC3 to coexist.
And than transfer room for room the devices and scene (also because switches in the wall have to be opened).
In the HC2 I have a command that switches off all lights at once.
It would be nice if I could send a command via a text message to the HC3 to start a scene there.
So that in the HC3 I can start a scene to switches off the divices too.
I Know, starting a scene via a URL is possible, but sending a URL this way from the HC2 not.
Thanks.
  • 1 month later...
    To communicate from the HC2 to the HC3 you can do the following....
    I created a VD, with three push buttons. (note! change sting in Lua)
    All three buttons controls devices or variables on the Home Center 3.
    note!
    Change IP 192.168.178.1, in your IP of your Home center 3..
    you need to change DeviceID=84 in the deviceID of your Double Switch.
    Code Button 1, to switch Fibaro Double switch  On:
    Code switch 2, to switch Fibaro Double switch Off:
    Button 3,
    First create a Global Varaible on the HC2 and on the HC3 with the name: MyGlobalValue
    in this example I use Authentication (user;password) admin;admin
    In the push button of the HC2 VD you program:
    By pressing button 1, 2 or 3 of your new VD, your double switch must be switched on or off, or the value of MyGlobalValue must be taken from your HC2 in the HC3.
    To start these pushbuttons from a scene, call the VD with its pushbutton 1,2 or 3.
    Suppose your VD has the ID 311, and want to switch on your device on the HC3,
    then the code in your scene is:
    Unfortunately, the connection is quite static.
    For example, you can't give the name of the variable from the scene. To send a value to that given variable.
    However, you can create a global variable with the deviceID, and then enable or disable the device with that deviceID on the HC3.
    I hope this helps..
    Edited by NLWaard
