Read a JSON with HC3
jguellec
Hi everyone,
I am (desperately) trying to retrieve JSON data from a website that provides French rivers levels (I am living close to the Seine river in Paris, and therefore I am quite interested when the river is getting close to flood height).
I already have a script that is working in Domoticz, but I’d like to have it running on my HC3. The existing scripts can be found here :
The website that returns the rivers data can be found here :
I’m not a developer, but I think this is standard JSON format ?
I would like to be able to run a scene that will get the data from this website, so I could send notification when it’s getting close to a given level.
I would perfectly be able to code this part, but how to read the JSON is a mystery for me !
Any help would be MUCH appreciated :)
20 answers to this question
Yes, it is json format.
I use
 to see the structure. Copy paste the output of
 and see the structure.
  • Well, thanks. I had a chance to look. I’m already using Firefox and I understood the structure of the file. What I don’t know is how to (using a scene or a quick app) I can get the last measure into a local or global variable
    If have written a simple QuickApp code which reads the values from the website and if a value is higher than the treshold, it gives a debug message
    or
    Edited by SmartHomeEddy
  • Wow !! Thank you so much ? !! That’s exactly what I’ve been trying to do.
    Thank you :)
    Well, I still don’t know what the readings logically mean. Still work to be done.
    At what interval you need to check the data?
    What is the treshold (I took 1.20) when do you need a notification?
    It looks like the data represent history and future?
  • Well, the refresh can be done every hour, or 30 minutes, it’s fine.
    For the threshold, I’m using 4.00 meters as a first warning. It’s getting serious after 5 meters.
    Yes, the data shows an history. I think it’s in Unix time (from January, 1st, 1970 :
    I didn’t had the time to check, but I’ll have a look later today.
    But again, thanks A LOT for your help. Much appreciated !
  • Ok, I had a look. The site provides 2 days of history. What is interesting is the last value (the most up to date one).
    So I confirm it’s Unix time, but for whatever reason it as 3 extra “0” at the end ?‍♂️
    For example : 1596448800000 represents 3/8/2020 12:00
    The date time can be formatted with this link:
        local url = "https://www.vigicrues.gouv.fr/services/observations.json/index.php?CdStationHydro=F700000103&FormatDate=iso&GrdSerie=H&FormatSortie=simple"
    (FormatDate=iso)
    This is an example debug output:
    I looked at the data and it doesn't look like a prediction, only history and actual water level. Or is there a timezone thing?
    I did some changes.
    The changed QuickApp:
  • Yes, I confirm. There’s no prediction, only observed levels from the last 2 days.
    I’m leaving for few hours, I’ll check your last version once I’ll be back :)
    Last question : I’m trying to get the latest value into a global variable. I know I should use the operator “#” to get the latest value in a table, but I’m not quite sure how I can achieve that In this case ?
    You’re very kind for the help !
    Your welcome
    Well, the level won’t go up from 1 meter to 5 meter in 10 minutes, so that won’t be a problem.
    Maybe it is more easy to read the value from the QuickApp. I have put the latest value in the Quickapp (and the date in de log) and added some labels.
  • Just tried your last version, it’s working great ! That’s exactly what I was looking for. You’re a boss ))
    Now I will play around with a scene to check the QA value and get push notification with pushover (I know how to do that at least ?).
    But again thanks for your help, and I’ve learn a lot looking at your code and I now better understand how QA works and how to read a JSON file. Much much appreciated ?
    Edited by jguellec
    You're welcome. I had many help from members of this forum. Glad to do something back. Now the sky is the limit ?
  • 1 hour ago, SmartHomeEddy said:
    (The QuickApp is available in the download section)
    Excellent ! I’ll download the latest version later today ✌️
    Thanks for the great work
    Hi
    Any chance you can share the link again? or the code here.. it is inaccessible.
