SOO 0
I have a HC3 (sw 5.040.37). I try to use the S2 input on a fibaro dimmer 2. I connected a dimmeble lamp to the dimmer and it works whit the S1 switch. I connected S2 to another switchbutton. (I used Homey befor this and also used S2 to toggle Fibaro wall plugs. It worked great. Just had a flow when button S2 is puched turn on/off lichts and used also the same wallplugs as i have now).
I try to make it work on HC3 but no luck yet.
The light on S1 works, both switches are pulse. I turned on scene activation (parameter 28) and maked a block scene. Look at the picture. But is doesnt work.
Why dont i have the same functions as a dubble switch, see attatchment Fibaro scene2.JPG. Like when i push S2 turn wall plug .... on / off.
29 answers to this question
