Aeotec Garage Door Controller ZW062 not available in Home Center
Aeotec Garage Door Controller ZW062 worked fine on old Fibaro app and FIbaro Home Center in laptop. On the Home Center App the Aeotec Garage Door Controller ZW062 does not appear at all. We are up to version 1.8.0 and this is still not fixed.
Is there any hope for a fix?
Guest CraigT
My question as well
For the time being, just make some scenes to do with your door what you want. The scenes will appear in your app.
  • 3 weeks later...
Now in version 1.9 and still no Aeotec garage door opener device visible. What say you Fibaro?
  • 3 months later...
Same problem experienced,
Can add device to HC3 but shows not configured.
Device actually does work from laptop interface, but does not appear in IOS app no matter what we do.
My Question is, will or does the HC3 support these Aoetec devices and if not, what is the work around to be able to operate the door and see the state of door opened or closed from the app on iphone.
Thanks in advance for any replies.
Ben
Wow. Still no support for this device in the app. This is crazy.  This is seriously the worst app upgrade I have ever seen.
Sure we can control the device with scenes, but what about creating a user experience for the users.
Absolutely terrible. At least the app now works and devices can be turned on and off, considering how long it took to have consistent performance in this terrible app I can see why a common device is still missing.
Time to look at alternate platforms, clearly not enough continued development support.
  • 1 month later...
.... now to try it out
