Open/Close the gate
I'm trying to build two scenes (Home center 2) for the garage door.
But so far without success :(
I have a qubino to open the gate and a Fibaro Door Sensor to indicate whether it is open or closed
The 1st scene was to open the gate when it is closed and if the gate is already open do not turn on the qubino
The 2nd scene was to close the gate when it is open and if the gate is already closed do not turn on the qubino
At this moment when I turn on the scene to open the gate and if it is already open then the qubino turns on and closes the gate
I'm sorry for my english :(
I hope you understand
17 answers to this question
Can you share your scenes (code or block) ?
    if the gate is open and I turn on the scene, the gate will close, and I don't want that. because i want it to open
    the idea is for me to be home and as I don’t see the gate,
    then turn on the scene to close the gate but if it is already closed it will open
    Edited by Vitor
    This scene is triggered by the sensor. If breached (the gate is open), then turn on the switch.
    I assume that if you set the scene into Manual Mode that will fix your problem.
    Yes, so if I understand your purpose right, you have two scenes, one to open and one to close the gate.
    But the scene must only do its job, when the gate is in the opposite position, open when closed and closed when open.
    3 hours ago, SmartHomeEddy said:
    Sim, então se entendi bem o seu propósito, você tem duas cenas, uma para abrir e outra para fechar o portão.
    Mas a cena só deve fazer seu trabalho, quando o portão está na posição oposta, aberto quando fechado e fechado quando aberto.
    yes, that's what i'm trying to do. but so far  without success :(
    Edited by Vitor
    But if this scene is to open the gate, should the sensor != breached ?
    If the sensor == breached the gate is open and you don’t want the “open scene” to do anything
    yes, i have tried many ways and the result is always the same. :( the gate changes its state (Open / Close).
    This scene was very important to me.
    I have Alexa and I tell her to close the gate but if the gate is already closed it opens, and I don't want that. :(
    Can you convert the block scene to Lua and post it?
    Then we can see what your scene does.
    2 hours ago, SmartHomeEddy said:
    Você pode converter a cena do bloco para Lua e postá-la?
    Então podemos ver o que sua cena faz.
    %% autostart
    %% properties
    387 value
    %% weather
    %% events
    %% globals
    if (
     ( tonumber(fibaro:getValue(387, "value")) > 0 )
    or
    then
        fibaro:startScene(152);
    This “open the gate” scene does exactly what you don’t want it to do. If the gate is open, turn on the power and therefor close it. And if the gate is closed, it doesn’t open.
    Can you try this (I don’t have a HC2) ?
    14 hours ago, SmartHomeEddy said:
    Essa cena de “abrir o portão” faz exatamente o que você não quer. Se o portão estiver aberto, ligue a energia e feche-a. E se o portão está fechado, ele não abre.
    Você pode tentar isso (eu não tenho um HC2)?
    :( Not Working
    [DEBUG] 09:39:55: 2020-08-07 09:39:55.944919 [ fatal] Unknown exception: /opt/fibaro/scenes/263.lua:12: ')' expected (to close '(' at line 10) near 'then'
    [DEBUG] 09:40:16: 2020-08-07 09:40:16.834625 [ fatal] Unknown exception: /opt/fibaro/scenes/263.lua:12: ')' expected (to close '(' at line 10) near 'then'
    Sorry, I think we have to lose the   ;  and a () and startSource
    Edited by SmartHomeEddy
    15 minutes ago, SmartHomeEddy said:
    Desculpe, acho que temos que perder o; e um () e startSource
    :) thank you very much :) it's already working.
    Now if the gate is closed it opens. But if the gate is open nothing happens :)
    I am very happy !!!
    Can you help make the other scene to close?
    The close scene is almost the same, you only want it to be closed when the gate is open and if it is already closed, nothing should happen.
    So only replace the if then with:
    It works :):)
    Thank you very much
