Zour Marom 0
Hi Everybody,
I'm looking for help with configuration of the Smart Implant device:
HUB - Universal Devices ISY
Use the Smart Implant to connect 2 analog sensors 0-10V output 3 wire.
According to the manual I should configure:
Connected to IN1: change parameter 20 to 4
• Connected to IN2: change parameter 21 to 4
When I try send the command my hub response with error message.
On attached file Nr 1 you can see the configuration window how i put the parameter, do I do it right ?
On attachment Nr 2 you can see the list of all the device show on my hub (Surrounded by a red frame) Are what is surrounded by yellow these are the INPUTS 1,2 ?
Thanks in advance for the help.
Zour Marom
