Lights off when lux is above XX
I have created a scene that turns off the lights when the lux level is above 40. But the scene only starts when there is a change in lux level. So when the lights are on and the lux level is already above 40 then the lights stay on until it, for example, changes from 80 to 60 or 80 to 200. That will trigger the scene.
How can I achieve that the lights also turn off when the lux is already above 40 without a change in lux level?
8 answers to this question
...that's, why i have no script at all in HC2 triggered by header... only looping.
sorry for offtopic. so about your qeustion you can add in header %autostart%
and check manually condition.
so when HC2 started or when you re-save scene - scene will running - check conditionla manually. it's easy
Edited by 10der
I use these two scenes to control my window lights during the day. (Slightly shortened)
-- Scene No. 1 - Is it Light or Dark
-- Scene No. 2 - On or Off
Edited by RH_Dreambox
    @RH_Dreambox
    Thank you for these scenes, they look useful for me. My only question is, what does that math.random with different values do?
    Random delay
    may be for fun effect no mote as for me just for fun ;)
    @kevin
    If you turn the lights on and off randomly, it looks more like someone is home even if the house is empty. That's why :-)
    Finally had the time to add this to my HC, unfortunately I get an error in scene 1 on the debug line. I can't see why but this is the error
    [DEBUG] 22:57:47: 2020-08-14 22:57:47.164521 [ fatal] Unknown exception: /opt/fibaro/scenes/314.lua:47: attempt to concatenate a nil value
    Have you entered your sensor ID both in the header and in the variable "Lux_sensor"?
    Yes I have. But it is already solved by a recreating the variable. Don’t know what was wrong with it because the error was only on the debug line.
    other question, do you have a working scene that lights turn off when XX minutes  no motion is detected.
    the one I have now doesn’t work great. It starts counting on the first motion but doesn’t start recouting when a new motion is detected.
