Hi
Im Serching for a simple Lua Script that sends me a Message when the outdoor temperature is under the indoor temperature.
My Outdoor temp Sensor is ID: 263 and indoor temp Sensor ID is 258.
Can me anybody help Please?
Thanks a Lot!
15 answers to this question
Hi @FabianM,
Maybe this can help.
    Thank You. Yes this helps me a lot.
    I now have make my own Lua Script but have one Problem. I Have to Trigger the scene manualy but i want to trigger the scene every time when the Temperature changes and pause after a post was sent.
    What is wrong in My Script?
    (Sorry some of the debug messages are in German, but that should not be the problem i think)
    Thanks!
    I think (I don’t use the HC2 any more) you need
    %% autostart
    %% autostart
    Unfortunately i already tried this, but it dont works though.
    Hi @FabianM.
    I'm not an expert in LUA and never had an HC2. But some forum members advice an infinty loop for checking the value's.
    Or maybe you could trigger the scene every minute or so with a time trigger, if the HC2 is capable of doing so.
    25 minutes ago, Flash said:
    Hi @FabianM.
    OK, but how i make souch a Loop? (Or Trigger Time)
    @FabianM
    I don't own a hc2 either but perhaps:
    if outside temp or inside temp changes run that scene
    Hi @akatar,
    Do you have a nice solutions how to detect the temperature changed? Without a infinty "While Do "loop or a time triggering.
    I found i HC3 LUA script from @10der.
    But I don't know how to convert it to HC2 LUA
    Device 490 is a lux sensor.
    conditions = {
            { type = "device",
            id = 490,
            property = "value",
            operator = "!=",
            value = -1
            isTrigger = true
        operator = "all"
    Edited by Flash
    @Flash
    I am sorry, perhaps a search on this forum will bring something up.
    No problem,  still learning and every input is always'welcome.
    @FabianM Well!
    HC2 can't have a crontab.
    so for periodicaly running you should use scene.
    my fav scene for it WAS (sorry i am on hc3 now) scene by @jgab - Timer
    just create scene with this body. thats all.
    the next step scheduling
    so we are need peridicaly checking,
    just create new empty script
    with this content
    @10der  Thank You. Looks realy dificult. I am still testing on it.
    But it is much different than my starting position. Is there no simpler way with just one Lua Scene like my scene? Where can i define the timeout time of the Message? How can i define only send the Push to my ids 99 and 1500?
    Is it not possible to change my existing Script to a Working one which triggers every time the temperature of my outdoor device is changing?
    Or do i make a mistake in thinking?
    Thanks for Answers and ideas! :-)
    Hi fabian,
    The problem with using a temperature as trigger is that it won't trigger with small changes and temperature changes aren't very big usually. I found this out recently. You can use the following script which will run every 5 minutes. With changed ID numbers it works here.
    PS: here it is also very hot right now and every evening I am happy to open all the windows ? (actually I open them early and all my shutters open automatically when the temp is low enough
    Edited by Jeroen_
    @Jeroen_  Thank You. Exactli what i think about it. I only was searching for the "while thrue do"
    - Now i add a "delete duplicate scene" Line and some indivitual sleep Times and my Lua Works like i want. Here is my Full Code. Anybody finds a error please let me know - but for now it is running like i want.
    Happy to help. In this case you don't need to delete duplicate scene's while there is no trigger for this scene. It will run directly after booting your system. The only way to create a duplicate is to start it manually. But of course it won't harm your code having it in there ?
