Smart Implant --> 24V Solenoid
Danshome
Has anyone ever tried to use the Smart Implant to open/close a 24v Solenoid valve?   I'm pretty sure I'm going to need Relay regardless because the Smart Implant has a max current of 150mA and my 24v Solenoid as a current of 833 mA.   But I'm not quite sure how to properly wire up the smart implant to the relay then to the solenoid.  Any advice would be appreciated.  There are plenty of examples online using Adrino to do this, but none with the Smart Implant that I could find.
Edited by Danshome
typo
5 answers to this question
Example with smart implant.
Every output should have it's own relay.
More NO (normaly open contact) could switch more actuators.
@SmartHomeEddy.
Just coincidence same amount of postings. ??
Edited by Flash
Not any more ?
But why a SmartImplant with a relais? Then a Relais switch is more easy?
Correct,
But @Danshome asked for smart implant.
Now he can choose.
Yet now same amount again.
Edited by Flash
I too have 24VAC solenoid valves but used relays that were actuated from FGS-222 modules. Wiring diagram
