It's an interesting idea, however I agree with @10der, you might want to go down the node-red route for that.
It will take some time to build interfaces, but you can do so much more and make it so much better.
In the spirit of helping out:
When you say you put Android on your pi, what do you mean?
If you install something like Raspbian you can just browse to your HC2 via Chromium or another browser if you prefer.
Or are you saying that you want to install Android so you can get the Fibaro Mobile App or Tablet App installed? In that case, I can't help as I have not tried this method before.
If you go down the Raspbian route you might want to hide the mouse cursor
Out of interest, what size screen did you buy?
@alex88 btw try google kiosk mode + rpi
Edited by 10der
I have read quite a few posts on kiosk mode. This is a good summary. Thanks!
None of them fix the problem of the mouse cursor always being present. Even then you unclutter the mouse pointer appears when you touch the screen which is ever so slightly annoying.
