I have succesfully used smartimplant to operate the garage door. I'm using Homecenter 2 with the latest firmware 4.6
But...
in the older fibaro app everything works as expected and the garagedoor switch does not appear in the wrong room.
in the newer homecenter app 1.8 there is something extra (categories) at the top of the screen under rooms.
It states that the garagedoor switch belongs to lighting wich is definitely wrong.
I want it to be under gates  how can i change this ?
Where are this categories managed ?
Check the categories of the device in the web UI. In the general tab you have category, probably is lightning noted here. You first need to add a second one before you can remove the lightning. In the advanced tab you also have controlled device, check what is selected here.
Edited by kevin
    Aha , that fixed it...
    I missed this..
    Thank you
