aaa426 2
Recently (I think since an update) my switches don't seem to be triggering associations.
I've got 2 x FGS-223s which I use without a load, just to trigger associations in other devices which don't have physical switches attached. I'm using S1 and S2 on one of them, and just S1 on the other.
If I use the physical switch attached to the 223, the relay clicks and the associated devices do their thing.
However, if I trigger via the Android app or Home Center configuration web page, then relay clicks, but the associations do NOT trigger.
I've tried a soft reconfigure, a hard one, and a full factory reset on one of the switches. Still the same behaviour. Anyone else seeing the same, or got any ideas about what might be wrong?
Firmware on the 223 is v3.4, and I'm on HC3 v5.040.37
Edited by aaa4262 answers to this question
