Dear,
I have an HC2 and I need a Scene when a Motion sensor is violated it turns on a dimmer in 100%, after 5 minutes without movement the dimmer reduces its light by 50% and another 5 minutes without movement the light goes out, but if this interval the Motion sensor is violated again the dimmer returns to 100% and the time counting resumes. I believe that this Scene is only possible through the Moon, if someone has a Scene like this or indicates a similar one I would be very grateful.
thanks!
8 answers to this question
maybe?
%% properties
88 value
%% killOtherInstances
local light=67
local sensor=88
If fibaro:getValue(sensor,”value”) > 0 then
    fibaro:call(67,”setValue”,100)
else
    fibaro:sleep(5*60*1000)
    fibaro:call(light,”setValue”,50)
    fibaro:call(light,”setValue”,0)
@jgab
IMHO 100 - restore prev value for dimmer. IMHO should be 99.
1 hour ago, 10der said:
@jgab
right
    Dear,
    jgab@ e 10der@
    thank you for your help, Cena worked perfect ....
    Hi @jgab
    off-topic, sorry but i have never seen %% killOtherInstances""
    Is that the same as checking only 1 instance is running?
    will kill any other instance of the scene that is already running.
    In the case of the scene example above if the sensor is breached it will turn on light and terminate the scene.
    When the scene trigger next because sensor becomes safe, it will go into a sleep/set light state that will take ~10min, and the scene will be active/run all the time
    However, if the sensor becomes breached again, it will kill the sleeping/set light scene (if it's running) and turn on the light and wait for the sensor to be safe again to enter the sleep/set light state again...
    Great to know, thanks @jgab!!!
