Quick help - Elgato Key Lights - to my knowledge there is no plough for this
I'm new in this space and send a warm welcome to the community !
I play around with these Quick App's for a while, but unfortunately I don't get it ;-)
Actually the requirement is quite simple: with Json I can control my Elgato Key Lights (https://www.elgato.com/de/gaming/key-light) on http://x.x.x.x:9123/elgato/lights.
to switch on with json
  "lights": [
      "on": 1
to switch off with json
  "lights": [
      "on": 0
would be very grateful if you could help me briefly.
Regards tom
    does everyone steer devices by Rest API?
    • 1 year later...
    Hey Tomblo do you have this working now or still not?
    • 3 weeks later...
    How can help to make it work on fibaro?
    Try this
    set quickAppVariable IP to the IP address of the light
    • 10 months later...
    On 6/6/2022 at 3:26 PM, jgab said:
    Try this
    Hi @jgab
    Its amazing how many great things you have put into this Forum
    I was wondering if you have an updates version of this QA?
    Its great with Color temperature - and i could i use dimmer function as well :-)
    I have two keylights - and i can just create two QA with different IP, but would it be possible to tweak/control both lights identical from the QA - looking the below function it seems that numberOfLights might can be used ?
    function QuickApp:turnOn()
      send("PUT","/lights",{numberOfLights=1,lights={{on=1}}},
        function(data) updateSettings(data.lights[1]) end
