trex 0
Hi.
I have 2 pieces of The Button (FGPB-101 v3.2) (called A and B) and 1 piece of Single Switch (FGS-213 v3.3) (called C). All added to the same Fibaro HC2.
For both of the buttons, I have added a single association to the single switch, so that a momentary push of on of the buttons should toggle the switch on or off.
This works fine, however this happens:
1. I use button A with one push to toggle switch C -> OK
2. I then use button B, but need to first push the button once, wait 2 seconds, then push same button again to make switch C toggle.
3. If I go back to button A, I then also need to push this twice with 2 seconds in between .
Is there something I don't understand when it comes to associations?
And yes, I could use a scene, but want this to function when HC2 is offline.
Anyone who has experienced this?
Tommy.
