API: Host not found (authoritative)
I have a simple scene with  setTimeout loop. And from time to time (may 1 time in a day, оr some times in a day) it hangs with an error
 [ error] API: Host not found (authoritative)
[ error] timer handler failed with error: /opt/fibaro/scenes/162.lua:15: attempt to index field  (a nil value)
it seems to me that this is due to an unstable link on GSM modem in router, but this should not affect the operation of the scene.  In addition, hovering can also occur when accessing a global variable.
Why is this happening?
Fibaro HC2 (4.600)
%% autostart
%% properties
%% events
%% globals
local id = 115
function sceneFunc()
    local state, lastModification = fibaro:get(id, "value");
    if (os.time() - lastModification > 3600) then fibaro:debug("More then 1 hour passed"); end
    setTimeout(sceneFunc, 1000);
sceneFunc();
