is it possible to call a VD from a VD?
what i want to achieve is this: i have multiple VD's. when i start primary VD, it shows a number of buttons. when i press button1, i want to call (show up) a second VD.
and if this is possible, is there a smart way to get back to the primary VD?
i prefer LUA code
I assume you are using the app for this.
I have searched for this as well, and did not find this feature.
What I did was, create extra rooms in one main room (Switchboard).
These rooms will then be your first buttons of your first VD.
If you select a room now, you will get to see all VD's in that room. If you open a VD there (in your example the second VD) you can control it.
Closing and going back to the first room cannot be done with a shortcut.
gr. Mike
