Twannie 33
Hi
I created a vd with door/window names with labels which holds the dev ID's
The VD is attached, look at the label names which actually is "lbl" and then the DEv id number in the system
I am stuck here
What I want to do is to scroll through the list and swap between "UIT" and "IN"
I then can use this info to enable or disable sensors
I hop you understand.
I do'n know how to scroll through the list using the buttons... maybe a good coder can help me on my way.
Thanks!!!
Edited by Twannie7 answers to this question
