Fibaro Profiles - perfect use?
Guest kallecux
Hello!
I'm thinking about using the profiles.
Of course, I can basically use it for “presence”, “absence” and “vacation”?
However, I wonder if there could be other uses….
For example, time-controlled or event-controlled (via button) profile activation such as "Good morning" or "evening" - however, it must be checked whether "Absent" or "Vacation" was switched on.
- How do you deal with it?
- Which profiles do you use?
- How do you control/activate the profiles?
- How do you regulate the topic “Good evening” or “Morning”?
Best regards Karl Heinz
