Greenhippo 5
Hi there folks,
I have a room with two doors and one light. Each door has a door/window sensor with an association to the light.
If you open one door, the light turns on. That's good. But then, if you open the other door, the light turns off. This is not desired behaviour; the light should remain on, until a door is closed.
Why is the opening of the second door causing the light to switch off?
For both door/window sensors:
All other parameters have default values.
The status of the light is shown correctly in the app/web UI at all times.
If the associated device (it's an FGS-223) is sent 255 by the first sensor and it turns on the light, then it is sent 255 by the second sensor, why does it turn off the light? 255 means "turn on", not "change your state"... what do I miss here?
Edited by Greenhippo5 answers to this question
