Sestorme 0
Hello
Let me get straight to the point .... I wrote a code that checks the presence of a household member in the room. If there is no violation of the motion detector within a specified period of time, possibly lighting will not be activated The state of the global variable should be "Absent" If the detector is violated or the switch is used, the state of the global variable should change to "Broken" I encountered the problem when I have 4 switches and 3 detectors ...How should I add them separately, if so, it will not slow down the operation of the air handling unit with more rooms?
Edited by Sestorme0 answers to this question
