How to change the IP ADDRESS FROM INTERNAL TO EXTERNAL IN HOME CENTER APP ON IOS ?
What I know you can’t.
why do want to change it manually to an external IP address? For remote login you can use Fibaro ID
Check general concept of Port Forwarding rules and try it.
I just tested and it works.
You can then block/disable remote access, i.e. you will not log in or anyone else using fibaro ID, which automatically increases the security of your network and HTC, and since you log in using IP, HTC3 does not know whether it is local or public IP with port forwarding
Edited by tnwirtu
