Guest Bastian
i connect a level tank sensor (Aqua Plomb from vegetronix) to an RGBW2 plug and measure my water level in a rain tank. The modul (ID780) shows the right % of fill level (94,4 % , 90 %,....) in Fibaro HC2.
Now i want to create a scene which will give me push notification when the water level will decrease under 20 % of tank level.
But every time the sensor is triggered i get an an push notification. No matter if the fill level is under 20 % or over 20%. E.g. at 94 % fill level i get a notification of "Tank level low"....
I wonder if i do anything wrong or why i cannot run the scene with ther %-values. Could be the problem that the scene cannnot use the "%-Value" ? Do i have to transform the %-value first to something else? Or can the scene only run by using the corresponding voltage value (like 20 % = 3 V and 90 % = 7 V) ?
The simple code i tried:
%% autostart
%% properties
780 value
%% weather
%% events
%% globals
if ( tonumber(fibaro:getValue(780, "value")) < 20 )
then
fibaro:call(398, "sendDefinedPushNotification", "15");
4 answers to this question
