Peak power consumption
Does anyone have a good scene or VD, or other tip, to capture peak power consumption per day for a device?
I run a VD every one minute which captures the current power consumption of the device in question and stores it if it higher then any previous value during the same day.
But what if power consumption peaks in between runs? my VD does not capture this.
Does anyone have a solution to this?
KR
P
8 answers to this question
KR
P
function showConsumption(energyMeterID)
    local cHM = os.date("%H:%M:%S | %y-%m-%d")
    local date = os.date("*t"os.time())
    local m = os.time {year = date.year, month = date.month, day = 01, hour = 00, min = 00, sec = 00}
    local t = os.time {year = date.year, month = date.month, day = date.day, hour = 00, min = 00, sec = 00}
    local day = os.date("*t"os.time {year = date.year, month = date.month, day = date.day}).day
    local thisMonth = date.month + 1
    local daysMonth = os.date("*t"os.time {year = date.year, month = thisMonth, day = 0}).day
    local day1Month = os.date("*t"os.time {year = date.year, month = date.month, day = 01}).day
    local powerMonth = api.get("/energy/" .. m .. "/now/single/devices/power/" .. energyMeterID)
    local powerToday = api.get("/energy/" .. t .. "/now/single/devices/power/" .. energyMeterID)
    local powerHour = api.get("/energy/now-3600/now/single/devices/power/" .. energyMeterID)
    local powerNow = api.get("/energy/now-1/now/single/devices/power/" .. energyMeterID)
    print("Now: " .. json.encode(powerNow.W) .. " W")
    print("Hour: " .. json.encode(powerHour.kWh) .. " kWh")
    print("Today: " .. json.encode(powerToday.kWh) .. " kWh")
    print("Month: " .. json.encode(powerMonth.kWh) .. " kWh")
local deviceID = 670
showConsumption(deviceID)
local startperiod = os.time() - 24 * 3600 -- last 24h
local endperiod = os.time()
local url =
    "/energy/"..tostring(startperiod).."/"..tostring(endperiod).."/summary-graph/devices/power/" .. deviceID
local events = api.get(url)
for k, v in pairs(events) do
    print(os.date('%Y-%m-%d %H:%M:%S', v[1]/1000), v[2])
Hi 10der,
Do you have the QuickApp version as well ( for HC 3 ) ?
With best regards,
Dan
53 minutes ago, Dann said:
Hi 10der,
With best regards,
Dan
yes
here
/monthly_2020_10/image.png.28b5fe8b3d6e1637c50c059ab737fd87.png" />
annonce me about washer start - end
left panel
  conditions = {
            id = 1873,
            isTrigger = true,
            operator = "!=",
            property = "userDescription",
            type = "device",
            value = ""
  operator = "any"
right panel
print("sourceTrigger", json.encode(sourceTrigger))
if sourceTrigger.property == "userDescription" then
    local event = json.decode(sourceTrigger.value)
    local action = ""
    if event.event == "start" then
        action = "started."
    elseif event.event == "stop"
        action = "ended."
    local report = "Washer " .. action
   -- telegram
    api.post("/devices/1818/action/sendMessage", {
        args = {report, "255464392"},
        delay = 0
Thanks 10der
I guess "1818" deviceID no. is the one of QA right ?
Looking forward to hear you,
With best regards,
Dan
2 hours ago, Dann said:
Thanks 10der
With best regards,
Dan
Yes telegram
I have posted this Qa some months ago
And btw you may used native push notifications from Fibaro instead of
But 1873 at the left it’s THIS Qa
Thanks 10der. ?.
Dan
Hi 10der,
As the QA is showing the Energy consumption within the time period showed ( and this is useful info ), do you think it is possible also to indicate the peak power value within the last 24 hours ?
It is the request of Perjar originally and I am interested as well on such power pick value.
As usual I am talking about HC3.
With BR
Dan
By pick power within last 24 hours I mean the highest instantaneously power value within the last 24 hours.
Dan
