Deleted Admin User
My HC2 has been playing up recently and I've been on the phone to support to try to fix it, but they have only made it worse.
At one point the person I was talking to, via TeamView, had ssh'd in to my HC2 and executed 'delete from New_Device where Id =2' in the DB which I think has deleted my admin user and now I can't get the main page to load, let alone restore a backup or repair the image.
Can anyone send me what is printed when you execute 'SELECT from New_Device where Id = 2' on the fibaro HC2 db?
14 answers to this question
Hi @MartynH,
Why don't you go into manual recovery and restore a back-up?
    9 hours ago, Flash said:
    Hi @MartynH,
    When i try to repair or recover (in fact any of the three options from the recovery menu) I get an error saying something about a corrupt image.  I've no idea how to fix at this point (and it seemed that Fibaro didn't know either).  They suggested I replace the battery on the motherboard which I'll try but I can't see how deleting the admin user will do anything good
    If a support member of Fibaro deleted your admin user, I think you should contact Fibaro how they think the issue can be solved.
    I saw a posting from @akatar.. Maybe you can ask him if he knows where to download a HC2 image to restore.
    Maybe the battery can be a cause for corrupting the image.
    I agree that @SmartHomeEddy. Is right. I don't know in what time frame support can/could assist. But you can always send a ticket and ask them for support.
    Edited by Flash
    @Martinh I experimented some with the url. This one gives an answer. Is that the version you are looking for?
    Edited by SmartHomeEddy
    I don't know if you actually can upload a image to a hc2? (i don't own a hc2 or hcl)
    if so, the url from @SmartHomeEddy could be the right one.
    I don’t know either ??
    I actually have shell access to the HC2, so pretty much have free reign to do anything I like to it.  I can upload images to it but am currently on 4.6 - I'll try flashing back to 4.54 and see if that works
    /opt/fibaro/scripts/update.sh (watch the params, it will not harm without them)
    3 hours ago, SmartHomeEddy said:
    no, these are migration images (4.180 to 4.5xx) and not recovery images. Migration images are not available for any version.
    Recovery image for HC2 can be found here
    Edited by tinman
    I've run the update scripts (with multiple params "--auto stable", "--auto beta", "--download 4.510 --install") and all look like they have worked, but they don't reset the DB.  What I really need is just a copy of the db from a fresh HC2 on 4.6 and I can reinstate the necessary user table as needed whilst keeping my HC2 specific data intact.
    @tinman are you able to provide me either the result of the "SELECT * from New_Device where ID=2" query or a fresh db?
    "2","0","0","2","16","admin","0","HC_user","1","1","0"
    that admin can be in your case as well email adress, check "SELECT * from NEW_Property where Device_id = 2"
    Edit: not sure is New_Device is still being in use, anyway, let's try if that makes your happier^^
    Edited by tinman
    Awesome - thanks for this.  Interesting that I thought this table designated user/superuser - but it seems that's all done in another table.
    I'll give this a go now - thanks again :)
    OK adding that to the New_Device table worked - thanks.
    I also had to tweak some changes I did the the New_Property table where I set the UserType to the wrong value.  Interestingly the UserType has to be set to
    (notice single quote ['] followed by double quote ["]).  So this worked for me:
    that's right, some values need double quoted values like UserType, so yes "superuser" as value is correct.
