HC2: CentralSceneEvent, two triggers
I have used a LUA script which is triggered by pushing the switch 2 on a Fibaro switch. Depending on whether the key is pushed once, twice or held, I control another device (a light) according to set rules. How the key is pushed, is found by the variable pressSource = fibaro:getSourceTrigger().event.data. This solution has been used previously by several contributors on the forum.
My current code looks like this (only first part shown):
%% properties
%% events
394 CentralSceneEvent
%% globals
-- Uses first slave for "CentralSceneEvent" ID (not master, not switch itself). Here 394
local trigger = fibaro:getSourceTrigger()
if (trigger.type == "other"then
    fibaro:debug("Scene started by clicking 'start' button")
else
    local pressSource = fibaro:getSourceTrigger().event.data
    fibaro:debug("New: CentralSceneEvent received from key: " .. pressSource.keyId)
    if (pressSource.keyId == 2then
        local ledId = "306"
        local ledValue = fibaro:getValue(ledId, "value")
        if pressSource.keyAttribute == "Pressed" then
            fibaro:debug("Pressed")
            if ledValue == "0" then
                fibaro:call(ledId, "turnOn")
            else
                fibaro:call(ledId, "turnOff")
        elseif pressSource.keyAttribute == "Pressed2" then
            fibaro:debug("Pressed 2 times")
            fibaro:call(ledId, "setValue""100")
        elseif pressSource.keyAttribute == "HeldDown" then
            -- etc. (complete code not shown)
I now want to add a second trigger, i.e. another Fibaro switch being pushed. Depending on which switch is used, I want different lights to be adjusted. Below is my first edit (still incomplete). In line 5, the new trigger 494 is added. How do I know if the scene was triggered by 394 or 494? The answer is probably in fibaro:getSourceTrigger(), but I cannot find the complete specification for this function documented anywhere. Specifically:
- How do I find whether 394 or 494 was the trigger? The syntax trigger.event.id in line 14 is my guest guess. What is correct?
- Once I have the right triggerID, I can easily make the variable ledID dependent on triggerID, by having two related lists (arrays): {394, 494} for the triggers and {306, 406} for the corresponding LED lights. This needs to be implemented in line 18.
Can anyone please provide a more complete specification for the data returned by fibaro:getSourceTrigger in HC2, and show me how I can use it to implement double triggers? Or are you all too busy converting to HC3?
PS: I have simplified this to TWO triggers. In reality I want to have several more. But if I can do two, I can do any number.
%% properties
%% events
494 CentralSceneEvent   -- <<--- NEW TRIGGER
%% globals
-- Uses first slave for "CentralSceneEvent" ID (not master, not switch itself). Here 394 and 494 respectively.
else
    local triggerID = trigger.event.id --  <<--- WHAT IS CORRECT SYNTAX??
        local ledId = "306" -- <<<< NEEDS TO BE CHANGED TO CORRESPOND TO triggerID
            else
            fibaro:debug("HeldDown")
5 answers to this question
You could use a different script for each switch. That is at least my solution. But I am also curious, if what you ask is possible.
    Using a different script for each switch is, of course, possible. But that is precisely what I wanted to avoid, as I increase the number of cases from one to eight! Let's see if someone can come up with a good solution!
    Well, you can make it arbitrary simple/complex...
    Thanks, @jgab ! I need some time to digest this. It got a little more complicated than I anticipated, but you have given me several clues as to how trigger.event.data calls are set up. I will certainly give it a try.
    Having reviewed your suggestion, I realize I can do it a little simpler. This is because in my case, the action to be taken is the same for all devices (on/off/change dim level, depending on the attribute). Only the device this is applied to is changed dependent on the trigger deviceId. With a few IF statements and a table of matching device id pairs, my problem is solved. Your contribution was still very valuable, as you showed me the syntax for the three functions/variables:
    On 9/14/2020 at 5:30 PM, jgab said:
    local deviceId = trigger.event.data.deviceId
    local keyId = trigger.event.data.keyId
    local keyAttribute = trigger.event.data.keyAttribute
    Which raises the question: Where are these HC2 variables documented? Cut-and-paste from experts like you is handy, but I would prefer to have a comprehensive documentation available. Previously I have copied and used fibaro:getSourceTrigger().event.data, which is not well documented either. Is there a complete description available anywhere of all these trigger event data variables?
    Again - thanks a lot @jgab for solving my immediate problem!
