HC3 send data to url on trigger
GJ Niewenhuijse
My goal is to send device changes from +- 20 fibaro devices to another api system. My devices are motion sensors, door sensors, smoke sensors and wallplugs.
I started to make a lua script:
How to make this script more generic, for example a script that triggers on every change in a range of devices? is that possible.
For example for device 1, 2, 7 and 10 a http request must be send when data changed for motion, light or temperature?
In the action i started a Quickapp, because i can't find a way to send direct http commands here:
How to get the ID and the VALUE this scripts is triggered from?
After that i make a Quickapp:
But now i get a http 401, how to solve this?
Anyone a better or more generic way to send data to another system with a api request?
Edited by GJ Niewenhuijse
Here is a QA that could inspire you. It sends all events to external systems subscribing to events. Like webhook.
you could filter the events on your list of devices before pushing them.
a multitigger with scene (power and state from dev 885, state from 939, any button click with centralscene dev, any button from sceneactivation dev, autostart after reboot and manually started)
Quote
of course one need later in scene code check the trigger
of course there is limitation with scene instances, so the code need to be fast or async to not miss events ...
Quote
the idea @jgab posted is actually much better, than a scene, because it does change with single instance any change. The same is being used in e.g. InitialState plugin, and it works very well, so for small integration one can work with scene, with larger of course with more scenes - or single QA.
Quote
KNX ?
Edited by tinman
    Thanks, that looks like the solution. But how to easely filter events?
    For example i like to get value changes for device 21 and 24 and battery changes for devices 21:
    deviceEvents =
       [21] = {'value','battery'},
       [24] = {'value'}
    • 8 months later...
    l'Hi,
    having issue getting this to work. I have only one goal - to trigger url from HC3 after tripple click of the button. I get all good, scene is triggered but url has not been sent. Tested in browser and url itself works. http://192.168.1.110/fcgi/do?action=OpenDoor&admin=&DoorNum=1
    • 1 month later...
    Hi Mart wellcome to the club,
    I have exacly the same problem using a Akuvox intercom. Let's hope together that someone will find out what's wrong with the HC3
